Replaceable bulb 6V Halogen headlights
Here is information on the headlights from Daniel Stern Lighting on the 6V Cibie E-code halogen bulb units. The replacement bulbs are very similar to that used in most cars sold today. Yep the initial reflector assembly is not cheap but should make a big difference in night driving, but I would not do this unless you put in the relay setup. I intend to do this soon.
Hi, Mr. White.
The lens-reflector units in your correct 7" shape/size are $60/ea. The
replaceable halogen bulbs that fit the lens-reflector units are $12/ea.
The bulbs are small enough that if you were to buy two pairs (a pair and a
spare pair) you could stash the spares wherever you want -- garage,
glovebox, under the seat, etc. -- and have 'em ready for easy replacement.
I imagine the lens-reflectors' price will probably give you pause, as
you're probably accustomed to paying $14 or so for a throwaway sealed
beam. However, keep in mind these headlamps I offer are designed and built
to last as a permanent part of the car, requiring only periodic bulb
replacement and aiming as maintenance. Meanwhile, your nighttime seeing
will be a GREAT deal better on low and high beam. You're quite correct
that the lamps will neither know nor care that the car is poz-ground.
ORDERING INSTRUCTIONS
Please indicate:
The quantity of each item you wish
The type of shipping you wish
(UPS trackable ground shipping is standard; all UPS service levels are
available)
The address to which you want the items shipped (if different from billing
address)
Whether the UPS driver has permission to leave the parcel at your doorstep
if you are not available to accept it in person.
You may voicemail or fax your order toll-free on 1-866-861-8668. Please
note this is a recorded orderline only. If you wish to speak to me in
person, please use 416-766-2327.
Orders may also be sent via e-mail to: dastern@torque.net
We accept Visa and Mastercard. Orders are processed securely.
Whatever method you use, the following information is required in order to
process a credit card order:
Card type
Card number
Expiry date
CVV code (last group of 3 or 4 digits on back of card)
Your name as it appears on the card
Billing address
Phone number
Please don't forget to include a note (such as a printout of our e-mail)
stating exactly which items you are ordering, and where you wish them
sent.
I look forward to hearing from you.
Best Regards,
DS
Hi, Mr. White.
Please indicate:
available)
address)
Card type
Card number
Expiry date
Billing address
Phone number
sent.
Best Regards,
DS
Thanks for the great info. Although the prices are not really that bad, I wonder what the lenses look like on these. Although you can't argue with being able to see more safety at night, appearance is important to those trying to keep an original look. Please share your experiences when you get around to doing the relay and headlight update.0
The body of the reflector looks pretty much like any sealed beam type light. Scroll down the page to see the 7" headlight.
http://www.danielsternlighting.com/products/products.html0 -
Lense looks a little different but as I said, being safe at night is more important. Thanks.0
- 174 The Flathead Forum
- 602 Vehicles
