need help with gas tank replacement...
[Deleted User]
Guys, just had the orginal tank for my 57 Hornet stripped and it looks like swiss cheese. By the look of it someone would have to make a new bottom because the strap has worn thru, the top and rear has about 2000 holes and the front is heavy pitted on the outside and feels soft.
Any 55-57 guys out there that knows if the 55 & 56 Hudson & Nash tank is the same? Does anyone out there have a good fuel tank for a 55 thru 57 Hudson or Nash?
I can have a custom one made for the car but I really want to keep this one as stock as possible. Even going to a fuel cell is not an option on this one since its 1 of 266 built. Even though its not a true Hudson its too rare to modify in my opinion.
thanks,
PaceRacer50
  • Check with Bill Albright.
  • Uncle Josh
    Uncle Josh Senior Contributor
    Take your old tank to your local sheet metal shop and they will make you one just like it.
  • 50C8DAN
    50C8DAN Senior Contributor
    Not sure where you are located but if you can find a Gas Tank Renu dealer near you they can fix your tank. Probably won't be cheap, mine was $200, but they do good work and stand behind it. The prices vary by dealership on a Studebaker tank one place quoted me over $300 and one 150 miles away $200!
    http://www.gastankrenu.com/
