Hudon 8 Heat Riser diagram
Does anyone have a good drawing or pictures of the heat riser valve assembly (for a Hudson 8) including the little arm and spring on the top. I took mine apart years ago and it now is a bit of a mystery of how it all goes together. I have te parts on the inside of the manifold OK it is just the way the rest fits together.
Thanks
Thanks
50C8DAN wrote:Does anyone have a good drawing or pictures of the heat riser valve assembly (for a Hudson 8) including the little arm and spring on the top. I took mine apart years ago and it now is a bit of a mystery of how it all goes together. I have te parts on the inside of the manifold OK it is just the way the rest fits together.
Thanks
I found this in my collection and thought it might be useful. It's showing the heater box counterweight on the left and coil spring with small anchor pin on the right. Off of a Twin H but I imagine the 8 is set up in similar fashion. Hope this helps. Best wishes! ArtS0 -
Thanks
Dan I just took these pictures of my 50 com. 8 they show the top but can not see the bottom.
hope they help.
LJ0 -
Thanks LJ that is exactly what I was looking for!0
