Hornet 308 coolant in the oil pan
Hey folks, Randy Owen here from Midsouth region. It's been a while since I've been on the forum.
The Hudson Hornet Special engine we rebuilt back in 2002 which now has ~
4000 miles on it, has developed a leak of coolant into the oil pan and
it is more than just a few drops, perhaps between and pint and a quart.
140 mile trip in late July showed no indications of a problem. But upon
draining the oil a couple weeks ago, I discovered the problem. The
coolant is totally drained from the car at this point. Considering the
size of the leak, I have discounted any effort to use any kind of block
seal. Originally we torqued the head bolts to the 65-70 lbs and
retorqued at least once. We DID use the copper spray-on type gasket
sealer as I recall. All new #8 bolts with the flat hardened washers.
I ordered one of those newer fiber-type gaskets from Dale Cooper. I
understand no gasket sealer is required to be used wirth this gasket?
Any suggestions would be appreciated for getting this car back on the
road. How many times and at what intervals should I retorque this engine? We just did it twice previously and within 500 miles.
Well, here are a link and thread on installing head gaskets.
Click on link and then scroll down to head gasket installation.
http://members.aol.com/stepdown53/STEPDOWNRESTORATIONAIDS.html#YOUR_STEPDOWN_COMPONENTS
http://www.classiccar.com/forums/showthread.php?t=4450&highlight=head+gasket0
