Window Frame Restoration
Unknown
My 50 Pacemaker shows some wear on the inside window trim. No doubt from windows down and arms resting on them.
Any suggestions on restoring/refinishing them? It is surface rust where the finish has been worn away over the years.
  • mars55
    mars55 Senior Contributor
    Does your window trim have wood graining on it?
    No, it is the antique pewter color or a silvery gray (depending on your perception).
  • i just unscrewed mine stripped them back and re painted them. no pic cos i still dont have a scanner
    OK. That sounds reasonable. I will see if the firm that is doing some powder coating for me has a color that is similar.
    I asked just to make sure there is nothing special about the part. I do not want to mess it up.
