Seeking distributor for 308
According to Pertronix, the "newer" dist for the 308 was made between 1950 - 55. Maker Autolite - IAT Series
Alternatively, a breaker plate for the older 48 - 49 dist would work. I'm pretty sure I can fix the one I've got, but a backup would be nice.
Any other dist options I might consider? Is there a more modern / common replacement that will work with the 308?
Thanks;
-Chirs
Thanks;
-Chirs
There have been some discussions in the past about using mid-'70's Chrysler electronic distributors- supposedly the only modification you have to make is machine a tiny bit off the shaft where it enters the block. Somebody hanging around the board surely knows the specifics.0
To whoever sent the private message re: "Seeking distributor for 308". My browser swallowd it, and classicar.com doesn't seem to give you more than one chance to read PMs.
Please send 2 messages to chris@chrishull.com
The first message should be titled "open says me", exactlly like that, all lower case. The second message should be the message you intend to send.
You can also try just sending a message to chull@ebay.com
Very sorry. Spammers make this crap necessary. Wish they'd just work for the DMV.
-Chris0 -
Mike (WA) wrote:There have been some discussions in the past about using mid-'70's Chrysler electronic distributors- supposedly the only modification you have to make is machine a tiny bit off the shaft where it enters the block. Somebody hanging around the board surely knows the specifics.
Here is the thread for the Chrysler electronic distributors:
http://www.classiccar.com/forums/showthread.php?t=996&highlight=slant
A thread for the Chrysler wiring diagram:
http://www.classiccar.com/forums/showthread.php?t=2672&highlight=slant0 -
Silly me. I figured out the messaging system on this board. And thanks for the info.
-Chris0
