New Glass for Stepdown Rear Windows
Unknown
I see that Bob's Classic Auto Glass is now selling new rear windows for stepdowns. Nice to know we will be able to get new glass for restorations.
  • Why is it the rear windows never "fog" and the same car will have front ones that did? What's with that? Another Hudson mystery.
  • russmaas
    russmaas Senior Contributor
    maybe because the fronts were two pieces slapped and the back was one piece thick?? Not for sure
  • 53jetman
    53jetman Senior Contributor
    Yes, that is correct. The rear window is tempered Herculite, and will not fog because it is a single piece of tempered glass. It will however explode if conditions are right, such as a high degree of heat build-up in the interior. It doesn't happen often, but is possible. Always crack a side window or two when your car has to set out in the hot sun!
    HudsonJetman@hotmail.com
    Jerry
  • A frequent cause of the "fogging" is the discoloration of the glue used to laminate the front and side glasses. Same as the bubbles, the two pieces are starting to separate.
