GIBSON-BINKS speed equip.
51hornetA wrote:I prefer 262 for street. 232 is fine if you are going full 7X and taking it to the track.
I agree on this one. I kept the 308 head on my 7X because of aftermarket pistons. When utilizing a 232 head on a Hornet engine, spark knock and poor gas becomes a VERY large issue. Power? Yes. Streetability? NO. The trade off becomes higher compression vs. distributor retarding.0 -
Which aftermarket pistons did you use?0
jahns pistons, 4" bore..0
7XPacemaker wrote:jahns pistons, 4" bore..
Okay folks, here we go. I believe you do not make power with any engine by going all the way out on bore size. You make it with cam, valves, porting, air flow, proper carburation, and if one can afford it stroking the crank. All you accomplish by going over a .090 bore is creating thin walls (unless you support with concrete (Hard Rock) up to the freeze plug for support and the head gasket hangs into the cylinder creating hot spots--thus detonation. The only gasket to prevent this is the copper gasket. I have done this and bored the gasket with by cylinders to form a perfect roundness around the cylinder. Then you need to O-ring the block for the copper gasket to seal correctly. Going more than .090 is impossible to get two O-rings between two cylinders due to lack of material between the cylinders. Always strive to keep the gasket sandwiched between the head and block and not protrucing into the cylinders. Bigger is not always better. Class dismissed for coffee and rolls.
Randy0 -
I have gaskets that are for my overbore and have no hotspot issues. The engine has been built this way for around 25 years with no problems. I will agree that it makes the cylinder walls thin, thus creating more heat. If I can quote some of the great racers "there is no replacement for displacement." Everything else that Randy says, I believe. Making power is taking everything to its limit, just to the hairy edge of failure. This includes valves, porting, etc. If you have created detonation or any other problem, then you went beyond that hairy edge, right? As an Aeronautical engineer, we are taught to extract the most amount of power with the least amount of material to reduce weight. Although not the exact same issue, they are strikingly similiar. The bottom line is this- everybody has a different prescription on what is best. Is anyone wrong? Is anyone right? I guess that it depends on your application.
By the way, I prefer doughnuts!0 -
I see that this thread was started early in the year and was picked up again recently. Whatever happened with the flow testing experiment and the molds for the two piece head? I am an engineer also and would love to know 'the rest of the story'.
P.S. I am not that far from Crossville and could assist in the flow test, or at least stand in the room and look dumb.
Hal0 -
greenhornet wrote:I see that this thread was started early in the year and was picked up again recently. Whatever happened with the flow testing experiment and the molds for the two piece head? I am an engineer also and would love to know 'the rest of the story'.
Hal
Greenhornet, send me a message and we'll try to hook up. The flow testing hopefully will get back on track soon. I've been overly occupied with things anti-Hudsonly this spring/summer.
Where in Tennessee are you? I'm in Red Boiling Springs
My e-mail hudfarm@nctc.com
Mark0 -
7XPacemaker wrote:I have gaskets that are for my overbore and have no hotspot issues. The engine has been built this way for around 25 years with no problems. I will agree that it makes the cylinder walls thin, thus creating more heat. If I can quote some of the great racers "there is no replacement for displacement." Everything else that Randy says, I believe. Making power is taking everything to its limit, just to the hairy edge of failure. This includes valves, porting, etc. If you have created detonation or any other problem, then you went beyond that hairy edge, right? As an Aeronautical engineer, we are taught to extract the most amount of power with the least amount of material to reduce weight. Although not the exact same issue, they are strikingly similiar. The bottom line is this- everybody has a different prescription on what is best. Is anyone wrong? Is anyone right? I guess that it depends on your application.
Well, I punched in 7X numbers into my computer desktop dyno comparing (3.905 -.090-overbore (323.4) cu. in.) to your (4.000 overbore (339.3) cu. in. a difference of 16 cu. in.
323
268 Hp & 313 torque at 4500 rpm
339
270 Hp & 315 torque at 4500 rpm
You gained many cu. in.'s but not in the right area.
I believe the racers you refer to were correct in their stance on cu. in. however, I believe they are referring to stroke cu. in. 350 chev. compared to 400 chev. The 350 is a 4.000 in bore and the 400 is a 4.125--the rest is stroke--where the power is. What make are your gaskets and where do you purchase them? Donuts with holes ready in the morning.
Randy
Randy0 -
Went back to the desk top dyno and stroked my 7X by .250 to 4.750 stroke with by 3.905 bore. I come up with 341 cu. in.--two more cubes than your 339. At 3500 RPM results:
323 cu. in 3.905 bore stock stroke 217HP 325Torque
341 cu. in 3.905 bore +.250 stroke 225 HP 338Torque
Randy0 -
Rudy Bennett asked me to post the following Gibson Intake manifold pictures... still need to put all this together and post to my Website... maybe this coming weekend. Cheers.
Happy Thanksgiving0 -
maasfh wrote:Went back to the desk top dyno and stroked my 7X by .250 to 4.750 stroke with by 3.905 bore. I come up with 341 cu. in.--two more cubes than your 339. At 3500 RPM results:
Randy
Randy,
Throw these numbers up for view from your Desktop Dyno. I don't have one anymore.
3.880 bore 5.00 stroke. Use your "Hot Cam" spec. Individual runner induction @ 525 cfm, with headers and pocket porting. 9.75 compression. I don't know how you simulated a weber setup in your calculations, but that is what I'm shooting for.
Then just for kicks, do the same specs with the exception of 4.250" bore and 625 cfm.
Mark0 -
Randy
I believe it was "Big Daddy" that said it. I don't have a Chevytop dyno, Nor do I race an 8 1/2 X 11 piece of paper that hypothetically shows me what I should have. I never did see at what RPM these figures were at. The problem with these programs are that that they have to be too generic. Can you calculate the distance of the intake runner and the angle of flow from the intake to the valve? A simple modification such as this can alter horsepower. Example: Put a 4.0 liter AMC head on an early model 258. The only way to TRULY know is to build each engine and put it on a dyno. I stated earlier that it depends on your application- this still stands. Multiple sidedraft carbs and such are great- if you can get them to run right. desktop dyno doesn't consider this. I remember at the Cleveland HET national a multi carb setup in a '41 got beat in a heads up drag by a modestly built jet with a 308. More CFM is not always the answer. Most people don't want to spend the money stroking a Hornet engine. They do what is most cost effective. If you think that boring a hornet engine doesn't change much- come to Doc's meet this spring and I'll show ya first hand, but don't spill your coffee on my interior and save the doughnuts for after the ride! Now, its time to quit playing deerhunter on the computer and try the real thing in Pa. EVERYBODY HAVE A GOOD THANKSGIVING!0 -
7XPacemaker wrote:I believe it was "Big Daddy" that said it. I don't have a Chevytop dyno, Nor do I race an 8 1/2 X 11 piece of paper that hypothetically shows me what I should have. I never did see at what RPM these figures were at. The problem with these programs are that that they have to be too generic. Can you calculate the distance of the intake runner and the angle of flow from the intake to the valve? A simple modification such as this can alter horsepower. Example: Put a 4.0 liter AMC head on an early model 258. The only way to TRULY know is to build each engine and put it on a dyno. I stated earlier that it depends on your application- this still stands. Multiple sidedraft carbs and such are great- if you can get them to run right. desktop dyno doesn't consider this. I remember at the Cleveland HET national a multi carb setup in a '41 got beat in a heads up drag by a modestly built jet with a 308. Also, more CFM is not always the answer. smaller cfm will sometimes produce more torque than a larger cfm carb. These engines don't like RPM too much, so I keep mine fairly modest and run a standard twin H. Most people don't want to spend the money stroking a Hornet engine. They do what is most cost effective. If you think that boring a hornet engine doesn't change much- come to Doc's meet this spring and I'll show ya first hand, but don't spill your coffee on my interior and save the doughnuts for after the ride! Now, its time to quit playing deerhunter on the computer and try the real thing in Pa. EVERYBODY HAVE A GOOD THANKSGIVING!
Actually, my whole goal is to eliminate the speculation and actually run the stroker in on a dyno. I'm also kinda tired of paper-tigers and want to know the facts rather than the best educated guesses. That being said, the engine dyno software is an excellent tool in comparing setups in advance to help decide such things as cam choices. Money well spent ahead of actual hard purchases. The non-chevy engines I've built over the years weren't exactly like the computer simulation, but close enough to see how the comparisons ahead of the build were benefited by the time spent with the software.
And yes, there is an engine design software out there that takes into consideration the runner length, and has port tuning simulation. Right down to the pressure wave harmonics through the intake tract. The name of the program is Dynomation, its about $500.00. The deal is, the more you know about your engine, the more you can simulate. The more real, hard numbers you can plug in - the more accurate the simulation is.
I'm going to agree on modestly built engines being on par with "over the top" engines in most cases - but only because the state of tune and knowledge of the tuner. I've been on both ends of that stick.
I'm also understanding of the cfm situation. The weber outfit I have will be matched to the flow number of each respective cylinder, and the vacuum signal at the jet will also be known. I was told a long time ago that each barrel of the weber outfit had to be tuned to its respective cylinder and I intend to take that tuning right down to the last variable - cfm capacity of each cylinder.
Maybe, we should sponsor a Hornet engine shootout - sure seems to be alot of us messing with these engines these days. I know the location of a dang good dyno facility.
Mark0 -
Big Daddy--Well I don't think you two are thinking along the same wave lengh when considering cu. in.'s and power. Go back and re-read--the rpm figure is stated. I have run sidedraft webers for over 15 years and have never had a problem tuning them. First started running on gas and then changed over to methanal. No problems. If the 41 you speak of got beat, there was a problem with the tuner. The desk top is an excelant tool as Mark has indicated. Maybe Santa should bring you one for christmas. I'm always up for a fast ride. I'll bring an extra head gasket. I'm also up for a race. Meet me at the tree. I'll be at Auburn for the National this year. I'm sure there is a track nearby. I'll bring my 54 coupe, small 7X (.060) overbore. I'll give you your extra cu. inches. Danny Spring & I are going to have a friendly race with both of our '41 coupes. We talked about it in Nebraska. Both have strokers. I can have both cars there. It will be fun. Have a great Thanksgiving everyone.0
there is a good (well decent) drag strip in Muncie which is south of Alburn
off of interstate 69. It's about 1 to 1-1/2 hours from Auburn. Its a easy drive
especially since its 4 lane for all but the last 4 or 5 miles.
they race on saturday's from april thru november.
i plan on taking my pacemaker there as that is the track we normally run
thru out the year.
They have 1/8 mile for the box bracket 1 cars and 1/4 mile for the no-box
bracket 2 cars and the street cars.
It would be cool to get five or six Hudson drag racers to meet up and go there saturday.
They usually open the gates between 11-12, start pratice at 1 and begin
eliminations at 5:00.
I do know the guys that run the track and I can contact them to see if they would let us Hudson guys race against each other in a special class. I've seen
the track manager do special things like that before. Personally i perfer 1/8
mile over 1/4 any more. its much safer in my book especially with vehicles
this old even though they are mechanically new.
I already believe Dany would be up for it. Any other's that may be interested?
PaceRacer500 -
maasfh wrote:Big Daddy--Well I don't think you two are thinking along the same wave lengh when considering cu. in.'s and power. Go back and re-read--the rpm figure is stated. I have run sidedraft webers for over 15 years and have never had a problem tuning them. First started running on gas and then changed over to methanal. No problems. If the 41 you speak of got beat, there was a problem with the tuner. The desk top is an excelant tool as Mark has indicated. Maybe Santa should bring you one for christmas. I'm always up for a fast ride. I'll bring an extra head gasket. I'm also up for a race. Meet me at the tree. I'll be at Auburn for the National this year. I'm sure there is a track nearby. I'll bring my 54 coupe, small 7X (.060) overbore. I'll give you your extra cu. inches. Danny Spring & I are going to have a friendly race with both of our '41 coupes. We talked about it in Nebraska. Both have strokers. I can have both cars there. It will be fun. Have a great Thanksgiving everyone.
Well, if I wasn't enthusiastic about going to the National before?
I AM NOW!!!
I can't promise I'll have anything to run - but this sure is incentive to try REALLY HARD!
Alright, I'm wound up now.
Mark0 -
Great= and looking forward to run. Do you run your hudson there on a regular basis? Muncie is about a 5 hr. drive from where I live in Illinois. Would like to meet up with you during the spring & summer since we like to travel to different tracks. I assume you live fairly close. Maybe Mark will have something together by the Nationals that he can bring at that time. Hopefully other Hudson hot rodders will bring their ride also.
Randy0 -
Guys,
i did not get a chance to run mine out this year. too many health issues with knees and back prevented me running any of my cars. i only went three times with friends. usually we go every weekend. last year we put over
390 passes on one car we race.
the guys i race with also race at Terra-Haute drag strip and that is closer
to you guys in Ill.
first weekend they race in april mine will be at Terra-Haute drag strip as the
guy i normally go racing with won a free entry for the entire year there.
kinda nice around here for drag racing. there are seven tracks within 1 to 2 hours drive from my house on the south side of indy.
once i find out something more from the guys at Muncie I will start a new thread here.
thanks,
PaceRacer500 -
Count me in also. I am going to the Nats. Just to see some Good-ole Hudsons drag Racing .Its been a long time ,hudson to hudson,and i remember them well, its just been to long .
I will be there just to cheer youall on. Hudsonly Rudy
( MABY a pit crew helper? ( my 46 308 wont be ready till next winter,that way i wont get beat by another Hudson )0 -
Come on Rudy, you're retired now, lets step it up.
Randy0 -
maasfh wrote:Come on Rudy, you're retired now, lets step it up.
Randy
Thanks so much Randy but, Trying to help 3 local Hud-NUTS build there engines and honey do this and that.
Will try a little harder on MINE.
By way,were you Pleased with the Clifford-Webber set -up that we sent ?
Did not get the chance to talk at the Nats. Had leave early.
But,we will be there next year for the BIG-HUDSON-SHOOT-OUT.
Hope all you H.E.T. ers Have a Good and Blessed day today.
Hudsonly, Rudy.0 -
Ok, Back when I was a lurker I read the begining of this thread and then it got by me. I just dug it up through the search function and read all 54 post's (whew!). This thread means a lot to Hudson newby's like my self who are trying to learn about Hot Rodding the 308. This is probably the most intresting topic of 2006. It has been at idle now for 6 weeks and I would love to hear more as I am heading down this road in the near future. Is there any up dates? I would love to hear more about what point you need to add additional mains to the crank, larger valve springs etc. The only thing I have been able to see or read about is on the uncommon web site. Is there any literature on the 308 break down or rebuilding tips. I'm more comfortable rebuilding SBC's and VW flat fours.
thanks again for all of the info, Joe
P.s. Can some one explain the pro's/con's with Weber down drafts vs. side drafts on the 308 if you didn't have any height limitations? Sorry for all of the questions but I'm sure I will have more.:o0 -
PaceRacer50 wrote:Any other's that may be interested?
One Jack Jockey volunteer right here. I can change an Indy tire in 8 seconds including the time to hit the start and stop buttons on the clock. Did some light tire swapping and gas passing' for a local truck racer in Indy a few years back. I know my daughter would love to see this as well. She'll gladly get dirty changing from street to track slicks and back in exchange for some driving tips and maybe a test run.
I am working hard to keep the Nationals inked into the schedule.0 -
seasons greetings
i fell across this chat while tryin to find out about engine mods for my 1917 huson super 6 . the porting isnt great as the early engines has the carb on the opposite side to the valves ,with passages through the block into the ports . standard they made 75 bhp @3500 and the team cars managed 115 bhp.
the valve guides have been cut down to help flow and 2 carbs . the cam is being re profiled but what else can be done ? compression is about 5-1 , would dome or wedge pistons be an advantage ? would stroking from 288 to maybe 360 be possible ? im only lookin for 120-150 bhp.
how much of this hornet info would be of use ?
cheers, james0 -
turkey wrote:seasons greetings
cheers, james
Have you been over at Yahoo Groups Hudson Super Six 1916-1929 ? More of the older Hudson chat over there. Good Luck, Ron0 -
I think altering a Clifford head to utilize domed pistons may increase compression & HP theoretically. However, the additiuonal compression would also induce head gasket failure.
Around this area (back in the day) the 'Modified' coupe racing Division allowed any Engine modification except blowers, and the big cube Flatheads with the aftermarket aluminum heads, pistons, Isky 505, etc could'nt hold a candle to the modified Hornets running 232 heads with 3 duces.... (The way Hornets were modified back then were crude compared with todays tecnology)
I think if someone invested & built an 'overhead Conversion' set-up for the Hornet it would unleash 'tremendous Power gains' like the Ardun Set-up did for Ford/Merc's Flathead....
Perhaps also have a billet Crank machined and bridge the 4 main brgs for additional support...
It would be cost prohibitive but a Guy can Dream........0
- 174 The Flathead Forum
- 600 Vehicles
