54 Hornet Electric Clock
Bob;
Access to the speed control is from the front. When you pull out the knob to set the hands, you will find a small "wheel" with a notch in it behind the knob. By turning that wheel you can change the speed setting of the clock. Hope this helps.
Tim in WI.0 -
Thanks, Tim. That is just what I needed.
Bob0
