I need a voltage regulator--source/Info??
JP
JP Expert Adviser
Thanks in advance for any helpful information.
My 54 Hornet needs a voltage regulator. I need some help finding one--some cross-listed "generic" maybe? The car is currently running (a Tom Swifty?) six-volt and negative ground.
Where can I find one that will work for my car? Any wiring caveats/suggestions with the stock-reversed polarity?
Muchos Gracias, und Danke. (I'm too new to this game to use "Hudsonly"--yet---that is).
JP
  • Geoff
    Geoff Senior Contributor
    There's one on ebay right now. 150065640440 In fact they come up quite often. Keep an eye out, or do a search on baymotors for voltage regulators. Most of the 3-coil 6 volt regulators will do the job, but the 45 amp ones are more suited.
    Geoff.
  • JP
    JP Expert Adviser
    Thanks Geoff,
    Hope to make it to the South Island some day.
    Cheers,
    JP
  • mars55
    mars55 Senior Contributor
    Voltage regulator for a '54 running a GGW generator is:
    Standard Motor Products: VR-4
    NAPA: VR27
    NAPA: VR27
    Do you have an NAPA no for the regulator that goes on a 50 Pacemaker? If so, would you share it with us?
  • mars55
    You are in luck.
    Voltage regulator for a '50 running a GDZ generator is:
    Standard Motor Products: VR-2
    NAPA: VR25
    No listing for the three brush generators 1949 and earlier (GEC).
  • mars55 wrote:
    You are in luck.
    NAPA: VR25
    Phantastisch. Das ist gute nachrichten. :):):)
  • 464Saloon
    464Saloon Senior Contributor
    I think I have two original regulators around here somewhere if anyone has to have an original.
    What year and model are they for?
  • JP
    JP Expert Adviser
    Just to mention thanks to everyone--I have a regulator.
    JP
