I need a voltage regulator--source/Info??
Thanks in advance for any helpful information.
My 54 Hornet needs a voltage regulator. I need some help finding one--some cross-listed "generic" maybe? The car is currently running (a Tom Swifty?) six-volt and negative ground.
Where can I find one that will work for my car? Any wiring caveats/suggestions with the stock-reversed polarity?
Muchos Gracias, und Danke. (I'm too new to this game to use "Hudsonly"--yet---that is).
JP
JP
There's one on ebay right now. 150065640440 In fact they come up quite often. Keep an eye out, or do a search on baymotors for voltage regulators. Most of the 3-coil 6 volt regulators will do the job, but the 45 amp ones are more suited.
Geoff.0 -
Thanks Geoff,
Hope to make it to the South Island some day.
Cheers,
JP0 -
Voltage regulator for a '54 running a GGW generator is:
Standard Motor Products: VR-4
NAPA: VR270 -
mars55 wrote:Voltage regulator for a '54 running a GGW generator is:
NAPA: VR27
Do you have an NAPA no for the regulator that goes on a 50 Pacemaker? If so, would you share it with us?0 -
Pacemaker500 wrote:Do you have an NAPA no for the regulator that goes on a 50 Pacemaker? If so, would you share it with us?
You are in luck.
Voltage regulator for a '50 running a GDZ generator is:
Standard Motor Products: VR-2
NAPA: VR25
No listing for the three brush generators 1949 and earlier (GEC).0 -
mars55 wrote:You are in luck.
NAPA: VR25
Phantastisch. Das ist gute nachrichten.
I think I have two original regulators around here somewhere if anyone has to have an original.0
464Saloon wrote:I think I have two original regulators around here somewhere if anyone has to have an original.
What year and model are they for?0 -
Just to mention thanks to everyone--I have a regulator.
JP0
