Wanted For 54 Wasp
I have a 1954 wasp with 3 speed OD transmission..I'm in need of the spedometer drive gear transmission end...It's the 18 gear model...
Also looking for the dealer installed back up switch that mounts on the gear shift lever and activated the back up lights need the switch and mounting bracket
THANKS
THANKS
TOM-WA- wrote:I have a 1954 wasp with 3 speed OD transmission..I'm in need of the spedometer drive gear transmission end...It's the 18 gear model...
THANKS
Check this site... they shoule beable to find a replacement. The switch is a Mechanical that is mounted on an L bracket... the linkage comes up and pushes plunger on swtich (a normally off set of contacts) makes the circuit while in Reverse and opens when out of reverse. Nothing special nor have to be Hudson part.
http://www.tciauto.com/components/speedometer_gears.htm
Good Luck and post your success here....0 -
Take a look at this ebay item may be what you want http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=34207&item=4522176081&rd=10
- 173 The Flathead Forum
- 599 Vehicles
