rear stabilizer bar bolt size?
Can't tell you much about the bolt other than it's not a hunk of threaded rod, but you'll need two (2) bushings.0
yorgatron wrote:does anyone know if there's a special bolt for the upper mount of the rear stabilizer (panhard) bar?
there was a piece of 1/2" allthread in there,but i know that's wrong.
also,when i order the rubber bushings from K-gap do i need to order 2 or 4 of'em?
This is indeed a large bolt that used a large washer and nut. When I replaced my bushings, my original bolt was in pretty rough shape, so I just scrounged around for a comparably sized bolt/nut to replace it.0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 605 Vehicles
