39 P/u As Rare As A Hens Tooth
Well now, I've got what's left of a 39 Country Club 8 in the woods with electric hand, and you could make yourself one pretty cheap.0
I've got the Model 97 129 in wb. Almost nothing will fit. What do you need, as I've also got a real solid model 93 112 wb which is the same as your pu. and everything is there albeit apart, and in good condition. Motor is apart but rebuildable. It's too good to part out however.
I'm in Northern NY, http://northvilleny.com0 -
Yup, after I get my friend's 42 out of the garage, and the 37 Terraplane doddlebug out of the driveway, I'll get back to my 40 coupe and 47 pickup. Whichever comes together first.0
there are 6 '39 pickups of all models that HET knows about.0
Maryland one is not listed. Massachusettes in the next closest... maybe you found a number 70
the only other "restored" '39 Big Boy I know of has a Jet engine & o. d. trans. + P. S., P. B., A/C & isn't painted or upholstered authentically.
The "Big Boy", model 98, is on the 119" w.b. & rated at 3/4 ton with the 3 X 5 engine as std. equip. whereas the model 90 is on the 112" w.b. with the 3 X 4 1/8" engine and I believe rated as a 1/2 ton PU.0 -
Rick,
do you know where in the NW that truck is?0 -
Rick,
Sounds like you and Uncle Josh REALLY need to get together.0 -
Hey, Pete, I'll trade you my restored '37 TP Model 71!!!0
no go, getting a '35 Railton conv. cp. instead, LOL0
Rick - contact Eldon, he's the one that's got the bucks (I've sold him several Hudsons that he has).0
