Need Starter for 37' Terraplane
Any good starter/Gen shop can do the job. It is not a big deal as it is an Autolite..0
You may want to swap out the solenoid first, to be sure it's not the problem.0
Just for grins, remove the small cap from the back of the solenoid and press the remote starter button in. This probably won't help, but if it DOES, then you will know the problem lies in between the solenoid and the starter button on the dash. Also, are you SURE you have clean connections at the battery and cables, and are you sure you have a 6 volt cable and not a 12 volt one?0
