oil filter
Yes mine has one,and if I can get it on the lift this week I'll try and post some pics.0
I have made several full flow filter conversions for my cars. I use a filter that inserts into the bottom of the oil pan and is covered by a removeable plate. It's the same in pan filter that GM uses. I can supply the weld in adapter and drawing if you are interested. 336-423-8703 Before 10:00 PM EST0
Rodder-Check with Lloyd Miller -(760) 360 6667 or Warren Bachtel (760) 345 2246. They had a real nice looking Full flow oil filter system on a 308. It required no modification to the block and a fairly easy midification of the oil pump. Norm0
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
