46/7 HUdson OD cable
EssexAdv
EssexAdv Expert Adviser, Member
Does anyone have a good 46/7 OD cable with switch they would like to sell. I need one for my very original 46 Super Brougham. Car has all the right parts in it even the OD is a 46.
I know I can use the later cable with an add on switch (that's how it is set uyp now), but this car deserves to be made right
Please. can you help?
Thanks
  • VicTor Z
    VicTor Z Senior Contributor
    Hell Lewis, I am parting out a '47 , with O.D. where is the cable with switch ? I will be going to my storage area next week end. Please describe the cable and where it connects to on the trans and the dash?? VicTor Z
  • EssexAdv
    The cable is under the dashboard. It is used to activate the OD.. Looks about the same as a stepdown cable except it has an electrical switch mounted to the bracket. The switch is activated when you pull out the cable
  • VicTor Z
    Wiil check fo it this Sat.
    VicTor
  • VicTor Z
    I have the OD cable for you. I guess I didn't say which Sat. Please send me your address again. Thanks for what you have done for the Hudson club, no charge! VicTor
  • EssexAdv
    Victor, I sent you a PM
