Marvel Mystery Oil in crankcase
Unknown
I regularly put Marvel Mystery Oil in the fuel tank of my 1950 Hudson Pacemaker Deluxe to lubricate the upper portion of the valves. However, how safe would it be to add some Marvel Mystery Oil to my crankcase to improve circulation? Does anyone out there add this oil treatment to there crankcase on a regular basis? Thanks for your response! Dan (1049superg).
  • hornet53
    hornet53 Senior Contributor
    Don't have an answer to your question, but that is an awesome picture! What's the story?
  • mars55
    mars55 Senior Contributor
    Here is a thread on oils you might find interesting.
    http://www.classiccar.com/forums/showthread.php?t=7757&highlight=engine+oil
  • I know two brothers who have always put a dash of top oil into the gas tank of the Cadillac they bought new 25 years ago. The car's appearance is pristine. Although the engine runs smooth and whisper quiet, who knows if the addition of oil has played any role in that. As far as MMO is concerned, it has a very high detergent action and may dislodge sludge that could then cause problems. Also, to much will lower oil viscosity. Like the old saying goes, "If it's not broke, don't fix it."
  • Geoff
    Geoff Senior Contributor
    I tear the newspaper up every day and toss it on the front lawn to keep the tigers away. Haven't had a tiger on the front lawn since I've been here, so it works real good.
  • Don't want to use it in the crankcase on a new engine; wait until it gets broken in and the rings are FULLY seated.
    Each time I change the oil in my automobile engines (even the lawn mower-use about 1 oz) I add 2-3 oz to the crankcase, plus I change the oil filter too, of course....at 2000 miles, and never more than 3K between changes.
    If you add to an older engine I would not initally put a full quart as is the maximum recommended by MMO Company. In addition, I would carefully monitor the change in color of the oil and as it blackens, change the oil and filter to keep it fresh looking and after time it will "clean up" the sludge within the engine, loosen the rings by cleaning the carbon out. I would never add more than 1/2 quart during an oil change, although it probably would not hurt anything, just clean things quicker.
    It also reduces the coefficient of friction internally (bearings, camshaft to cam bearing, timing chain, etc) and allows the engine to get slightly better gas mileage. Same rational effect by addition to the gas tank to improve top cylinder lubrication.
    It is the best oil additive as far as I am concerned.
  • tigermoth
    tigermoth Expert Adviser
    i have a 70 year old motor that had a sticking valve problem. an older mechanic suggested i add a few ounces of MMO to every other gas fill up and to the oil at each change. i have not had a problem with that valve since. (6 years) regards, tom
    Geoff. You are the greatest, as usual you make sense. But I bet most of the younger fellows cannot figure out what you said.
  • Geoff,
    Boy, you can sure learn a lot on this forum! I have a Tiger problem here in Ohio. Does it matter if you use the front page, Sports section, or the whole paper?
    A young Hudson owner
  • Nevada Hudson
    Nevada Hudson Senior Contributor
    Is that what happened to the Tasmanian Tiger?
  • SuperDave
    SuperDave Senior Contributor
    Really.. what's with the Plane?? I used to work on the USAF version of that Lockheed lady.. RC-121-D as I recall.. I don't recognize the paint scheme..Is that the Navy version?
    Davew Fl
  • Geoff you have to be crazy not to believe in the "miracle" of Marvel Mystery Oil. I had a dent in my fender and I put a little MMO in the tank and dabbed a little behind each ear. When I came out in the morning not only was my dent gone but my bumpers were extra shiny. Now any rational man would not try and explain that away. Since then I have been using it without fail have not seen a dent in my car since. And finally if that isn't enough my hair is full and shiny. Must be the MMO can't think of any other explanantion off hand.
  • Geoff
    I forgot to mention, I haven't had any elephants on the lawn either, so it must work for those too. Seriously though , it really gets back to the fact that if any product was as good as it is made out to be, the manufacturers would either recommend it in their products, or use it from the start. I don't have any experience with the said additive, as we can't get it here, but there used to be a product called Redex available here, whcih was promoted as an upper cylinder lubricant. It quietly died from the scene. Currently, the additive that has been promoted is Valvemaster, which is supposed to protect your valves from the dreaded unleaded petrol. I have just stripped my Essex motor down, first time for 22 years, as it was starting to rattle a little. there were two connecting rods starting to peg out, which I replaced. There was very little carbon in the cylinders or on the valves and stems. The exhaust valves just needed a very small amount of lapping in to be perfect, and I replaced the rings and the two rods. I need not have done the rings, but since I had the motor apart thought I may as well. This engine has been run exclusively on unleaded fuel, with absolutely no additives, and using 20W-50 oil, for 22 years, (around 80,000 miles). I think that this demonstrates that our Hudson-built engines will perform perfectly well on unleaded fuel, without additives of any type. The use of "upper cylinder lubricant" is unnecessary in my opinion. I fail to see how any additive can lubricate the valve stems effectively, as sit would have to remain unburnt during the combustion to effectivel be deposited ont he hot exhaust valve stem and face. Lead was promoted as a valve lubricant, but in my experience this caused as many problems as it solved, as the lead would build up on the stems and faces, causing the valve to jam in the guide, and the build up of lead on the face would increae the tappet clearance. Okay, I know some people are going to swear by this stuff, and it probably doesn't do any damage, but I remain to be convinced of the effectiveness of any "Miracle" product. Remember the old Water injectors, which were supposed to increae valve life, stop pinking, stop burning valves, prevent carbon formation,give huge increases in fuel economy, etc. etc. Well, I had on of those on my car for 10 years, way back in the sixties, and the only thing I could ascertain was that it did actually use water. There was no other discernible benefit. I took it off when it siphoned half a gallon of water into the inlet manifold overnight when the diaphragm developed a leak. There was again, no detectable difference when the car was running without it. I rest my case. Incidentally, if my old faithful Essex goes as far between overhauls as it did last time, I'll be 92 before I need to touch it again.
    Geoff.
  • Could it be nothing more than marvel is a mystery?
  • TwinH
    TwinH Senior Contributor
    Oh yah, love me some connies or 121's as this seems to be. Stripped one
    20 some years ago ,and now have one for a neighbor. Flew in a couple
    years ago. Missed approach to a grass field with no flaps(exhausted their
    supply of hydraulic fluid) still greased it with probably no more than 10*
    flaps second time around. Whats the story on this one?
  • Thanks to everyone regarding the use of Marvel Mystery Oil. My engine, a 232 in a '50 Pacemaker, has just under 70,000 miles on it. A little over a year ago, I had the oil pump gear, timing chain and gears and rear main seal replaced on the engine. Consequently, the oil pan was removed and cleaned. Nonetheless, it looks like the best way to use this oil is to go easy with a few ounces at first. I have an oil change coming up shortly and maybe I'll add some Marvel and drive around a bit before changing the oil.
    A few people inquired about the photo I posted. The photo, which was taken about 1994, shows my 1950 Pacemaker with a former US Navy C-121 Super Constellation at what was then Chanute Air Force Base at Rantoul, IL. Chanute had an aviation maintenance school for U.S. Air Force personel. Consequently, there were many aircraft that were used by the base personel to train on and then they were put on display throughout the base. This included aircraft such as a massive 10 engine Convair B-36 Peacemaker, Convair B-58 Hustler, B-66, C-97 Stratofreighter, a B-29 superfortress,
    about four B-52's and many fighter aircraft including such famous planes such as the P-51 and F-86.
    Back in the pre 9-11 days, a civilian could visit the base by simply signing in at the base gate and then drive around sometimes directly up to the aircraft on display such as I did with the C-121 "Connie".
    Chanute closed as an Air Force base back in the late 1990's and is now an industrial "air park" that's been quite successful so far. The aircraft that were on display are now part of a museum at the former base. Many of the smaller Air Force aircraft are now in a hanger with the larger ones outdoors such as an early XB-47 Stratobomber and of couse the Navy "Connie" which was lovingly restored in it's original dark colors by a group of retired Navy personel who use to fly these four engined "triple tailed" radar recon birds back during the cold war days.
    By the way, the rare B-36 now resides at a former airbase in California and the B-29 is at the National Atomic weapons museum at Alburquerque, New Mexico. The Hustler is still at Chanute. All the B-52's were scrapped to comply with the U.S.-Russian arms agreement cutbacks.
    Hudsonly, Dan
  • I GRADUATED BROM AIR FORCE BASIC TRAININ IN DEC 54 AND WAS TO GO TO CHANUTE FOR A/C MECHANIC, BUT AT THE LAST MINUTE WAS SENT TO DOVER AFB, DEL AS A PERSONNEL CLERK IN A SQUADRON OF C124S, SPENT 4 YEARS THERE OUR PUTFIT WAS CONVERTING TO C133S WHEN I WAS DISCHARGED IN SEP 58. I REMEMBER THE CARS PARKED AROUND THE BARRACKS MY FIRST SERGEANT HAD A 56 LINCOLN A MILE LONG, ANOTHER SGT GOT A NEW 55 CHEVY IN THE ORANGE AND WHITE COLOR, IT WAS A KNOCKOUT. I HADNT DISCOVER HUDSONS AT THAT TIME, BUT HAVE MADE UP FOR IT SINCE, sREGARDS, BILL ALBRIGHT
  • TwinH
    If your ever in central Fl,be sure and check out www.fantasyofflight.com
    worlds greatest aircraft collection. Has to be the largest collection of
    airworthy warbirds and vintage aircraft anywhere. Take home a 40's
    vintage Allison V12 or two. New in the crate! $$
  • Tinker AFB has an EC-121 on a stick just outside the AWACS headquarters building. It was a former Navy plane and re-numbered with a fictitious "552" door number to match the 552 AWAC Wing. It was flown into Tinker in 1984 from Davis-Monthan AFB, AZ and was repainted and restored at Tinker before being placed on static display. Many AWAC'ers at the time had Connie flight time, as well, so many got to sign their names on various equipment inside before she was closed up for the last time. Those big Wright 9-cylinder radial engines have the most magnificent sound to them!
    I was an AWACS E-3 crewdawg for nearly 18 years. We took an E-3 to McClellan AFB, CA for a reunion of Connie and E-3 flyers and a small airshow in 1996. At this event was the only remaining flying EC-121 (part of the Confederate (now Commemorative) Air Force), and along with the E-3 parked next to it, made for a great picture for us crewmembers!
    Tinker's EC-121. Click on the pic for that plane's history. - http://www.aero-web.org/database/aircraft/getimage.htm?id=3714
  • Nice photo of the Tinker AFB C-121 Connie! I use to be a member of the organization, "Save-A-Connie" which is now the Airline History Museum at downtown airport, Kansas City, MO. They have a restored Lockheed 1049 Super "G" Constellation in TWA colors that they fly to air shows throughout the country. Back in the 1990's I was privileged to fly three times on their "Connie" between Chicago and K.C. including flying into and out of Glenview Naval Air Station which is now no more being covered with expensive new homes. Taking off in a Constellation was a thrilling experience as the four powerful Wright 3350 18 cylinder radial engines would be opened wide open on takeoff providing an incredible symphony of blaring propellers along with orange and blue flames shooting out of the three exhaust tubes on each engine. I made it a point to document each flight with black and white and color photos along with video taping the highlights of each flight. Enough said on Connies and planes as I believe this is a discussion group on Hudsons!
    By the way, I think I'll hold off on putting that Marvel Mystery Oil in the crankcase of my '50 Pacemaker as it seems the Jury is still out on the potential benefits of this mystery concoction. I will say this, however, on occasion I read in the auto section/mechanical advice of the premier Chicago newspapers that Marvel Mystery Oil is a good substitue for engines that used leaded gas. Of course, this is adding the oil to the fuel tank versus the crankcase.
    Hudsonly, Dan
  • SuperDave
    An intersting note about those radial engines. They used three power recovery turbines (PRT's)in the exhaust stacks that had fluid coupelings back to the crank shaft. Sort of like a turbo charger, but without the blower. They would glow red hot.I don't recall how much power they supposedly "recovered" from the exhaust. I wonder if that would work on a 308?
  • Actually, the PRT's (also called "Parts recovery turbines"!) send around 100 hp each back to the engine. They are connected via fluid couplings to the nose case. Basically, it's "free power".
    (Recip Flight engineer in training)
  • SamJ
    SamJ Senior Contributor
    It is worth noting that Marvel Mystery Oil is not a new product...it's been around for over 80 years. After many, many years as an independent business, it is now owned by the company that makes Turtle Wax. The product is very well respected in the industry.
    http://www.marvelmysteryoil.com/main.taf?p=1
    Geoff, I haven't had a Tiger in my tank (or on my lawn) since Esso became Exxon, but I do use MMO in my '40 H. If it does nothing else, it lowers the evaporation point of modern gas to help prevent vapor lock. Even if it dosen't do everything it says it will, adding it makes me feel better, which is worth the price of the product.
    Oh, and Geoff...the Spitfire airplane used water injection...I guess those RR engines needed all the help they could get...:cool:
  • "Oh, and Geoff...the Spitfire airplane used water injection...I guess those RR engines needed all the help they could get...:cool"...Sam J...
    For what it is worth... For over 20 years I depended on water injection into the engines powering the USAF Jet on which I crewed. Losing water on take off was NEVER a fun event!
    Cheers from Texas... like Sam I dump the MMO into the tank.
  • hudsontech
    hudsontech Senior Contributor
    Thanks for a memory - I flew out of NAS Jax (Jacksonville to you uninitiated) back around '57, '58 as a flight crewman in the Connie doing hurricane flights. We came back from one flight with the skin on both wings wrinkled and so many missing rivets I wondered how the thing stayed glued together.
    I walked into the Ops Office and immediately requested transfer back to my home unit there in Jax - VF-171. We had F2H-3 and 4 Banjo's (Banshees) in 171 - and they were single crew planes. Much better, thank you. LOL
  • Newspapers are amazing, I think George Goble used then when he was stationed in Tulsa during World War II. Not one German plane made it past Tulsa!
