Woodworking shop with 5-axis router?
I'm trying to get a particular Hudson wood part replicated, and in multiples (to cut costs). At this point it seems that a 5-axis router may be one cost-effective way to do that.
Does anyone work for, or know of...
1) A custom woodworking or furniture shop, or prototyping company, in Pennsylvania, Maryland, Virginia, W. Virginia or Delaware, which has such a machine, or
2) A distributor or manufacturer's representative of a 5-axis routers, which might give me the name of a woodworking company (in the above area) which has purchased such a machine?
Many thanks for any leads! I'll monitor this thread for any suggestions.
These are all CNC router shops.
Premium Wood Products, Inc.
436 East Locust St
DeKalb, IL 60115
Phone: (815) 787-3669
http://www.premiumwoodproducts.com/quality.htm
League Manufacturing
608 Furman Rd., P.O. Box 3626
Greenville, SC 29608-3626
phone: 864-232-4423
http://www.leaguemfg.com/wood.htm
Packnet Ltd.
1172 East Cliff Rd.
Burnsville, MN 55337
http://www.packnetltd.com/cnc.html0 -
Thanks, Ted! I'll write these down. Of course, if you happen to hear of one a bit closer to Northern Virginia, I would certainly appreciate your letting me know!0
Jon B wrote:I'm trying to get a particular Hudson wood part replicated, and in multiples (to cut costs). At this point it seems that a 5-axis router may be one cost-effective way to do that.
what are you trying to make ?
Iam a cabinetmaker by trade and have a 3-4 axis machine (cnc)
along way a way but I send stuff to Hawaii (whole kitchens)
ps if you know anyone that can draw in auto cad these drawings can normally be imported straight into machines so it keeps down your programming costs
mike0 -
Mike, thanks for your thoughts. I'm trying to replicate a convertible top header (about 5 ft. long). It curves every which way and is fairly complicated. I'm sure you could do it, but the problem is, we will have to have it digitally scanned, then have a prototype made, then fit it to 3 - 4 cars to make darned sure it fits, then possibly modify it (if it doesn't), and so forth 'til we have it ready to produce. If I had a local company doing this, I could drive my Terraplane over and check the fit, as the job progresses.
Now, I have no problem with bringing my car to your beautiful country for a fitting, but first I would need water wings, and second, the gasoline consumption of a floating Terraplane would be MURDER! LOL!0 -
at least its timber alot easier to work than steel, the other way it might work as a thought , could you cast 1 out fibre glass and the make a mould , and recast carbon or kevla copy wth timber in the centre for what ever fixings you need0
Put Me Down For One When Ready Bill Albright0
Timberline, LLC - Henderson, NC
Manufacturer, Service Company
Company Profile: Precision machined wood parts & assemblies. CNC capabilities. Custom manufacturer of wood boxes, containers & packaging.
http://www.timberlinellc.com/SpecialtyWood.htm
GF League Co. - Greenville, SC (Serving North Carolina)
Manufacturer, Custom Manufacturer
Company Profile: Manufacturer of woodworking elements, parts & other products, custom CNC fabricated, for architectural purposes, packaging, store fixtures, textiles & conveyors. Hardwood, softwood, wood composite...
http://www.leaguemfg.com/wood.htm0 -
Many thanks for any leads! I'll monitor this thread for any suggestions.0 -
Guys, there is a rapid prototype shop near me in Southern NH (I know, too far away) which can laser scan a part, creating a solid model which can then be imported into a CNC machine (be it wood or metal). Surely there is some similar shop in your area. Good luck, Mike Bergeron0
Guys, thanks for all these good ideas.
Again, the reason for my seeking a computer-driven router is that we now need 7 of these items and they're rather large and complicated. If I only needed one I would not hesitate to find a skilled woodworker, but unless some craftsman out there is willing to work for peanuts, mechanization seems to be the key to getting these items turned out 1) inexpensively, and 2) with precisely identical dimensions.
Also, I would like to explore shops that are a bit closer to home. In due time it may be that I'll have to stray far afield to find someone to do the work, so thank you for all your suggestions.0
- 994 Street Rods
- 175 The Flathead Forum
- 602 Vehicles
