is it a 308?
It's a 308 with a 262 head. The rib is readily identifiable as you look under the generator and go straight back to the rear of the driver's side of the block.0
66patrick66 wrote:It's a 308 with a 262 head. The rib is readily identifiable as you look under the generator and go straight back to the rear of the driver's side of the block.
thank you ,i thought that the rib was to be partial and up higher, but i thank you very much for the info.
now all i have to do is identify the year...lol0 -
its a 55 or 56 3080
nick s wrote:its a 55 or 56 308
hmm, ok thank you. i guess that would mean that we have hyd lifters and relieved valves, should be a ok combination from what i hear.any input on that?0 -
Hey, that looks very much like the 1950 Super Six from M.Rosauer which was on craiglist the other day. Again a lost chance for me ;-)0
Well Only Allthe 56's Had Hyd. Lifters Some 55's Were Solids0
Yes i bought it from Mark the other day.0
gearhead wrote:Yes i bought it from Mark the other day.
i have been looking for a good driver since my 52 coupe isnt done yet0 -
I received some pics and a discription from Mark. Is the body really solid (except on hole) ?
I also thought it may be a good driver. Wish you good luck with it.0 -
Enfield wrote:I received some pics and a discription from Mark. Is the body really solid (except on hole) ?
the body is awsume,needs a good block and buff as far as the paint goes,im going thru all the brakes and such. the chrome was all done a few years ago. it does run great with exception of poor idle,but i will take care of that. any way thankyou0
