46/7 HUdson OD cable
Does anyone have a good 46/7 OD cable with switch they would like to sell. I need one for my very original 46 Super Brougham. Car has all the right parts in it even the OD is a 46.
I know I can use the later cable with an add on switch (that's how it is set uyp now), but this car deserves to be made right
Please. can you help?
Thanks
Thanks
Hell Lewis, I am parting out a '47 , with O.D. where is the cable with switch ? I will be going to my storage area next week end. Please describe the cable and where it connects to on the trans and the dash?? VicTor Z0
The cable is under the dashboard. It is used to activate the OD.. Looks about the same as a stepdown cable except it has an electrical switch mounted to the bracket. The switch is activated when you pull out the cable0
Wiil check fo it this Sat.
VicTor0 -
I have the OD cable for you. I guess I didn't say which Sat. Please send me your address again. Thanks for what you have done for the Hudson club, no charge! VicTor0
Victor, I sent you a PM0
