Speedometer worm gear
LanceB
Does anyone have a NAPA part number or a replacement speedometer worm gear for a three speed transmission. I have a 46 Hudson pickup. Thanks.
  • As you may know, Al Saffrahn in Arizona rebuilds overdrive (and maybe other) Hudson transmissions and you might want to address that question to him. He's listed in the H-E-T roster.
  • YOU PROBLY DONT NEED THE WORM GEAR IN TRNS BUT THE DRIVE GEAR THAT GOES ON THE END OF SPEEDO CABLE, AM I CORRECTss?? BILL ALBRIGHT
  • If it's the speedo pinion you need and not the worm gear on the tranny shaft, the Stewart Warner number on the gear is 104853 (10 teeth).
  • Your correct Bill and thanks Park.
