HUDSON 8 1930 rear shocks
Bror, if you can bring yourself to fit non-original parts, convert to modern telescopic shock absorbers on the rear. it is relativley simple to do, and gives a vastly superior ride. You will need to makeu up a suitable bracket to bolt under the spring U-bolts nuts, and drill a hole in the chassis for the top std to go through. Good luck,
Geoff.0 -
If your car uses the old lever-action shocks and you want to go 'authentic', possibly these people can help you: http://www.applehydraulics.com/0
Jon B wrote:If your car uses the old lever-action shocks and you want to go 'authentic', possibly these people can help you: http://www.applehydraulics.com/
Thank you Geoff and Jon B see what is the best will stay with the old if I can find ones somewhere
Bror0
