Radiator
Does anyone know of an Aluminium radiator from a late model that will fit in the step-down brackets and have the water connections on the proper side ?
( if so how many tubes ) Will the Aluminium cool any better than a copper-brass one? Thanks to all. RUDY.
LI dont know about an alum rad. but I use rads from 70*s doge pickup with 360 engine. has correct outlet position you need to trim the side mountings with a die cutter. they work great, about 160 to 175 dollars,, bill albright0
Thanks Bill for the help. Rudy.0
