1950 C8 cylinder head
Hi all
I´ve been listening and learning in the background for some months now.
Some great tech tips along the way for me fixing my 50C8. I´ve stripped it totally (although I said I wouldn´t), stripped the paint, Sandblasted everything, fixed some rust, had it painted and it´s now coming together again.
Problem:
I just realized that the head was shot. It´s cracked quite badly, and someone tried to fix it, so it is noy really repairable. It hasn´t leaked before, but is now after a thorough cleaning.
Does someone have one for sale?
I also need the screwclips for the grille. All of them.
Greatful for any tip.
Will try to post pictures of the progress later (if there is interest)
Thanks
Ola
Problem:
Thanks
Ola
The Swede wrote:Hi all
Problem:
Thanks
Ola
There is interest! What do you think were doing here, lets see it.
Chuck G0 -
would a 47 head be the same ? i have one of those. n..w. wisconsin0
see your email, found one0
I also have a very nice one for sale if someone else needs one.0
Ok. Great! It appears Bill A. had a good one, so that one´s solved for now. About the grille clips: Does anyone know of a AuVeCo equvivalent that might work? Or something from another brand?0
Are you taking about the stainless clips on the grill?. If so, you can use restoration specialties #2356. These are the same type but wider. Need to zip off so only one line shows and rotate 90 degrees. Just use them last week for my 50 grill0
Great tip. Would it be possible to post a picture so I can make sure it´s the right one?0
I have an entire engine with 17,000 miles if interested?
Thanks0 -
How Much for the engine? Does it need anything? Where are you?
Thanks
Joe0
