Any interchage of clutch/pressure plate available for a 54 Jet?
Unknown
Hello All:
I recently purchased a 1954 Super Jet and was wondering if there was any interchange of the clutch and pressure plate that anyone knew of.
I heard somewhere that certain years of Dodges would work, but I can't confirm that, nor did I get the information as to what years worked.
Any help that can be provided would be greatly appreciated!
Thanks in Advance!
  • Geoff
    Geoff Senior Contributor
    The Jet uses the same pressure plate and disc as the '55-'56 Hornets, and are interchangeable with Chysler/Dodge and Studebaker, not sure exactly which years, but definitely the fifties.
    Geoff.
  • faustmb
    faustmb Senior Contributor
    Last time I changed a clutch in a 53 Jet, I bought a new replacement disk from NAPA. I think they looked it up in the printed catalogs for the Jet.
    Matt
  • saame as 53 and 54 FORD, ALSO BILL ALBRIGHT
  • dwardo99
    dwardo99 Expert Adviser
    I have a pressure plate and disc but no throwout bearing, if you're interested.
  • mars55
    mars55 Senior Contributor
    Jets used a 9 1/8 inch Borg & Beck clutch. A modern replacement would be a 1960 to end of production Dodge or Plymouth slant six with 9 1/4 inch clutch.
