Chicago
[Deleted User]
Has anyone had some Hudson engine work done in the Chicago area and recommend a good mechanic?
  • What sort of work are you looking to have done?
  • Valves and water pump.
  • I had the rear main seal, timing gears and chain and oil pump gear replaced as well as some brake work done to my 1950 Hudson Pacemaker at Good People Automotive in Freeport, IL back in 2005. Their number is 815-232-5543. They've worked on a number of Hudsons in the recent past.
    Dan
  • If Freeport is too far north, give Gus Souza of West Chicago a call. He's listed in the HET roster.
