Hudsonkid's wish list....
Well, as most of you know, I got the OD back in my hudson.
I'm in the process of wiring it back up. I want to try my hand at using the original hookups, so here's what I'm needing at this point....
I need 1 working OD relay for a 50 hudson, or whatever else may work. I want to maintain the original style white 4 prong connector, so whatever else out there that might work, let me know. Also, if you got suggestions as to what might work aftermarket, meaning over the counter parts, that I can make work, hey, drop me that idea as well....
I also need 1 kickdown switch, the one that mounts under the gas pedal, with all mounting hardware. This needs to be for a 50 also, or whatever else works, I prefer the original style, again, with the 4 prong connector. Also, here again, I'm easy to make happy, got a better idea of an aftermarket over the counter part, lemme know!
Last item, I need one bracket that goes on the trans that the cable hooks to. This is something that if no one has a part, I will be able to "borrow" one off the OD unit on the back of one of the OD units laying around at hudsondad's, but don't tell him that, yet. The problem is that it is difficult to get to, and my preference is to see if anyone out there has one they just want to ship out for a good price. Also, if anyone has a good picture of one, maybe I can just make on, or modify something to make it work, but I figure this isn't worth the effort.
Many thanks!
also, if anyone needs, I got a few extra parts here, some NOS, etc... that I would be willing to trade, sell, etc...
just a few....
Battery filler in the box
50 pacemaker lower V struts,
rear C-6 door handles 48-50 pair NOS
6v 6cylinder Sun tach transmitter (need a little work)
Best!
Hudsonkid
Many thanks!
just a few....
Best!
Hudsonkid
Overdrive kick down switch- : NAPA OD 6284, about $15.49. Same one is available from Jeepster Man for 19.00 http://www.thejeepsterman.com/shopdisplayproducts.asp?page=70
dave s wrote:Overdrive kick down switch- : NAPA OD 6284, about $15.49. Same one is available from Jeepster Man for 19.00 http://www.thejeepsterman.com/shopdisplayproducts.asp?page=7
ordered a 6284 from NAPA, also picked up 3 of the 369 U-joints.
getting closer.....0 -
Did you find a relay for the OD? Would be interested in obtaining one myself, so if you have a part number, source, etc... ?
whatever I find is MINE MINE MINE hahahahaha...
actually, if I find an alternative, or a second one, I will be glad to pass it on.
I'm down to a relay and a bracket. not bad.0
- 175 The Flathead Forum
- 602 Vehicles
