Tyre sizes
rockin tom
Hello,
one short question: I want to change the tyres of my 52 pacemaker into wide white-walls. The size is 8,2 x 15.
The normal size is 7 x 15 (?) i think... ?
Is that possiple on the same wheel rim?
Thanks a lot
Hudsonly
Tom
Thanks a lot
Hudsonly
Tom
Now i know a little bit more.
The standart size is 7.60 - 15. My reserve tyre is that size.
Actually i have 205 / 75 /15 on it.
I think there is no Problem with the bigger size 8.20 - 15. The guy who sells the tyres to me, said that the diameter difference between 7.60 - 15 and 8.20 - 15 is round about 1 inch. The difference between the 205 / 75 / 15 is about 2.5 inches. And the breadth is about 1/2 inch more.
I think i'll make the change.0 -
They'll fit on the wheel. You may have fun getting them on or off the rear due to fender clearance. I think 7.10 - 15 was the standard and you can probably get 7.60s on. I'm running R225 - 75 - 15s and struggle to get them on and off the rear. There's several previous threads on tire sizes you can look up0
Standard tires for stepdown's were
7:10-15, equivalent to 215-75 R15
Optional tires were
7:60-15, equivalent to 225-75 R15
Rims, standard 5x15, optional 5.50 x 150 -
Thank you for the answers.
I know about the other threads about tire sizes. But on everywhere they spoke about radial sizes.
I think i will try the 8.20 - 15 as a second set of wheels. I have some 5.5 inch rims, i will put them on it. If driving is too bad with the diagonal 8.20 - 15 i am even able to put back on the radials.
It seems like nobody tried to put the 8.20 - 15 with the 5.5 rims on a hudson. So i will do. I hope the car does not "swim" too much on the street.
And i hope that the bigger diameter of the 8.20ies helps to bring the rpm of my engine a little bit down... :rolleyes:0 -
Hi If you need help E-Mail www.FatWhiteWalls.com . Trust your Classic to Someone Who Drives One . Hudson Dave
Or call 352- 564- 4284 0
