Front Brake Hose
hdsn49
hdsn49 Senior Contributor
Does anybody know the correct number or where to find the flexible front brake hose for a 49 Hudson. The united numbers I have are no longer good.
  • Wagner #24070 Norm
  • hdsn49
    Thanks, The correct Wagner number is F24070. The new napa number is 36794.
    As usual the forum comes through.
  • J Spencer
    J Spencer Expert Adviser
    Also H19015 is the number at Advance Auto Parts. Bendix and others use this number also.
    Jim Spencer
  • Are these numbers the same for the front brake hoses on a 51 Hornet?
    You are correct.
  • J Spencer
    Hudzilla wrote:
    You are correct.
    49 - 54 (Except Jet)
    Jim
  • Jim-'48 to '54 Norm
  • Thanks everyone. Anyone have the Napa part number for wheel cylinders for a 51 Hornet?
  • Left front wheel cylinder 18290 right front wheel cylinder 1891 those are wagner numbers running at $13 each at NAPA I paid $1o each at schucks.
  • Right Front- WC 40952. Left Front- WC 40951
    Right Rear- WC 59241. Left Rear- WC 59240.
    These are Wagner #s. On the rear cyl.s the steel brake line screws directly into the cyls. (No adapter fitting like the origional Hudson cyls.) Norm
  • Thanks for the info
  • are these actual wheel cylinders???
    that seems cheap for an extra set...
    for the price of a rebuild kit, why even bother?
  • J Spencer
    herm wrote:
    Jim-'48 to '54 Norm
    Norm, you are correct. My bad. Actually I knew that' somehow I blew it.
    JIm
