Rear Axel for Dummies
Unknown
I have a leak at the differtial cover of my 52 Hornet with a 308. I have several questions. I would like to simply replace the gasket. Is that possible? I see a filler plug, is there a drain plug? When I take off the housing cover what else will fall out beside the gasket? Any other advice is much appreciated.
  • The answers are:
    Yes
    No
    Hopefully, nothing other than old fluid.
  • I like yes and no answers. It the hopefully part that I'm worried about.
  • Geoff
    Geoff Senior Contributor
    Removing the bottom bolt of the cover drains the housing. If anything else falls out you are in deep doo-doos!
    Me too. Unless you're having a big problem with your rear end (or that of your car), the guts won't fall out when you drain it.
  • Go to your auto parts store for a gasket to fit a Dana/spicer 44 rear cover, Jeeps or some Fords up until 1956 used that rearend. If fluid hasn't been changed in a long time, you may have to scoop it out, I have used an old Hudson dipstick and a rag to reach the front on my Studebaker. Lou Cote
