Answer to Zinc concerns
37 CTS
37 CTS Senior Contributor
http://www.castrol.com/castrol/genericarticle.do?categoryId=82915470&contentId=7032644#top
This is the solutiion to our concerns re Zinc and oil.
Castrol Syntech 20/50 is formulated to have zinc protection for all older and street rod cars. check the above web site .
It is in stock at Advance Auto parts and others.
Concerns are over, dont have to put Diesel Oils in the Super Six!
29 Vic
  • Never been much of a Castrol user. I've used either Amsoil or Shell Rotella T since the late '80s and haven't HAD to switch. I'll look and see what those two have to say about their current oils before I'll do anything else.
  • Jim Kilday
    Jim Kilday Expert Adviser
    Is Castrol Syntec a non-detergent oil and if not, is it "safe" to use it in an engine that has been using Castrol Non-Detergent 30W oil for many years?
  • Is 20/50 ok for a splasher? I once read that for the splasher engines it was recommended to use a lighter weight like 10/30. This would allow the oil to splash around more. Any thoughts?
  • Has anyone used MOTORHEAD Hi-Z MOTOR OIL, that is advertised in WTN?
    Amsoil recommended their 15W-40 diesel marine oil.
    BN
