Answer to Zinc concerns
http://www.castrol.com/castrol/genericarticle.do?categoryId=82915470&contentId=7032644#top
This is the solutiion to our concerns re Zinc and oil.
Castrol Syntech 20/50 is formulated to have zinc protection for all older and street rod cars. check the above web site .
It is in stock at Advance Auto parts and others.
Concerns are over, dont have to put Diesel Oils in the Super Six!
29 Vic
29 Vic
Never been much of a Castrol user. I've used either Amsoil or Shell Rotella T since the late '80s and haven't HAD to switch. I'll look and see what those two have to say about their current oils before I'll do anything else.0
Is Castrol Syntec a non-detergent oil and if not, is it "safe" to use it in an engine that has been using Castrol Non-Detergent 30W oil for many years?0
Is 20/50 ok for a splasher? I once read that for the splasher engines it was recommended to use a lighter weight like 10/30. This would allow the oil to splash around more. Any thoughts?0
Has anyone used MOTORHEAD Hi-Z MOTOR OIL, that is advertised in WTN?
Amsoil recommended their 15W-40 diesel marine oil.
BN0
