12 V fuel pump for 51 Hornet
Borg Warner #EP11 for 6 volt and EP12B for 12 volt0
Dave, The local NAPA store says that EP12B is not a good number. Borg-Warner website is no help, any further thoughts? Walt0
Walbro makes several belows type pumps in 6 and 12 Volts. Their No. 2404 replaces the old WEP11- 6 V pump which has a capacity of 4-6 PSI. In 12 Volt, there are three pumps. Two with fixed pressure, one variable. The fixed pressure pumps are: 2401 (replaces WEP12) 4-6 PSI; 2402 (replaces WEP13) 2.5-4.0 PSI and 2403, (replaces WEP 38), which is a variable pressure pump that can be set between 1.75 and 6.0 PSI. It is shown in the J.C. Whitney catalog under the old No. WEP 38. J.C. Whitney lists fixed pressure pumps at 39.99. Walbro lists fixed at $55.000
