Front disk brakes on stepdown
50C8DAN
50C8DAN Senior Contributor
OK is anyone still making the front disk brake setup for the stepdowns? The last thread said one guy would not make them anymore.
  • Dan, The Labud system is made to fit Hudson stepdowns and is ,I believe, still available from the Labuds. {See roster for their Florida address}. Rick Pridemore of North Carolina still has units available for stepdowns and apparently reconsidered his thoughts on stepping away from the manufacture of those setups.
  • 464Saloon
    464Saloon Senior Contributor
    If no one ever reproduces drums for our cars the disc kit will someday be the only option.
  • That or go start measuring and see if anything else uses a brake drum of the same width and diameter. You get those two right, you can always have the center holes machined larger and the bolt pattern redrilled.
