Aligning doors on 29E RS
Can't quite understand your question, but I assume you have a gap between the front edge of the door and the frame. You need to put a length of steel strip (1/4" or so thick) in between the hinge sections, and shut the door on it so you strain the hinge forward. Probably what has happened is the door has swung back at some stage and bent the hinge backwards. Alternatively, you can put washers between the hinges and body and door.
Geoff.0
- 175 The Flathead Forum
- 602 Vehicles
