part needed
Try Hudzilla, He posts on here all the time. 704-792-9110
Bob0 -
A 232 or 262 is the same thing and is more available.0
Josh,
Pullys are available but I think any welding shop can weld it up and be as strong as original; They pre heat then slow cool in sand.... In a pinch If the pully is not broken out too far perhaps file the edges and reuse. I have found motors that had a little piece of pully missing perhaps for yrs with no apparent belt problem. Depends on break...0 -
The break is bad enough that there is no way that a belt would stay on it. BJ TN thanks for the tip...I will try to get ahold of Hudzilla.0
