part needed
Unknown
anyone know where I might find a crank pulley for a 308? I was in the process of pulling mine when the jaws of the puller slipped and broke a side off... are these cast? Or could a good welder fix it?
  • Try Hudzilla, He posts on here all the time. 704-792-9110
    Bob
  • Uncle Josh
    Uncle Josh Senior Contributor
    A 232 or 262 is the same thing and is more available.
  • Ol racer
    Ol racer Senior Contributor
    Josh,
    Pullys are available but I think any welding shop can weld it up and be as strong as original; They pre heat then slow cool in sand.... In a pinch If the pully is not broken out too far perhaps file the edges and reuse. I have found motors that had a little piece of pully missing perhaps for yrs with no apparent belt problem. Depends on break...
  • The break is bad enough that there is no way that a belt would stay on it. BJ TN thanks for the tip...I will try to get ahold of Hudzilla.
