Experimental Torpedo Boat
  • Nice tiller.
  • Jon B
    Jon B Administrator
    I like the 'World War II era" tiller, yes! That CERTAINLY authenticates the craft to the correct time period, doesn't it! LOL!
  • bent metal
    bent metal Senior Contributor
    where do I put the trolling motor? hhmmmm, I'm going to have to think about this one.
  • A 30mm machine gun mount, eh? So, how is it supposed to be aimed and fired if it's BEHIND both of the crew?
  • hudsontech
    hudsontech Senior Contributor
    That appears to be an experimental two man stealth craft. The idea is it would be used to take two commandos to a beach to do recon, sabotage or whatever.
    I seriously doubt it would have had a machine gun, .30 cal or other wise, in actual operation - the idea being stealth. The motor would probably have been electric, powered by storage batteries.
    The Brits had something similar - only theirs was submersible. I beleive the Italians also had something along the British idea.
    Looking closer at the photos, it is obvious that somebody has reupholstered the seats - in actual use the seats would most likely had no covering. Also, the term "torpedo boat" is far fetched - it's not big enough for that, for one thing, and the sponsons near the back aren't big enough to carry torpedos of the day, if indeed it was even built in WWII. Now, limpet mines were a possibility. Maneuver the craft into an enemy harbor, slide over the side and take the mine to the hull of an enemy ship, set the timer and a couple hours later, BOOM.
    In any event you do have to take your hats off to the fellows who might have been required to use it, if indeed it made it past the prototype stage. I doubt that it did - most beach recon during WWII was done by the frogmen, precursors to todays SEALS.
    Alex Burr
    HudsonTech
    Memphis, TN
  • Dear User:
    Unfortunately, access to this particular category or item has been blocked due to legal restrictions in your home country. Based on our discussions with concerned government agencies and eBay community members, we have taken these steps to reduce the chance of inappropriate items being displayed. Regrettably, in some cases this policy may prevent users from accessing items that do not violate the law. At this time, we are working on less restrictive alternatives. Please accept our apologies for any inconvenience this may cause you, and we hope you may find other items of interest on eBay.
    Thank You.
    Hit the return button to return to the previous page.
    Did anyone save some pics? I'm always a day late and a dollar short LOL
  • Rick, did you ever think that your 2000th post would be about an aluminium boat equipped with a Weiner Dog and a cut down Hudson steering wheel?
  • It's a surplus belly tank, made into a runabout, mid-50s era. I saw a couple similar ones years ago in the fingerlakes area of NY. That would look exactly the same if there was a green Johnson 5 1/2 HP Sea-Horse hanging on the back. cheap fun! It's a shame they cut a Hudson wheel, there were tons of generic ones back then, different colored plastic, etc. that could have been used.
  • BTW a 30 mm MG mount? HAHAHAHAHA! even a .30 cal mg would rip that mount off if the steering was in the front position and the rear seat flopped around. (a 30mm is the size of the cannon in an A-10 Warthog, a tank-killer) The weight of a 30mm barrell alone would sink this rig. It was likely a small flagstaff mount.
  • Wow.... that's just wild! Wonder why Ebay pulled THAT?
    Thanks for re-posting the pics!
  • SamJ
    SamJ Senior Contributor
    I saw something similar (made out of a belly tank) in the (gulp!) '60's, when I had a small racing hydroplane (which we called "Sea Fleas"). This thing appears to have a lump on the bottom, but unless it has some kind of keel, it isn't going very far. Even a canoe has a keel. :cool:
