Jet front engine mounts.
I was in a Engineering supplies shop this morning, and spied an industrial mount that is an exact replacement for the front mounts for the Jet, except that instead of a 7/16" stud in the top plate, it has a threaded hole for a 10mm bolt. As K-Gap don't make a Jet mount, I am willing to obtain these if any one is interested, and post them to you. Cost, not cheap I'm afraid, at U.S.$40 each, plus postage, but they are a heavy duty mount, and professional quality. If interested, contact me direct at email, geoffclark@xtra.co.nz
Geoff.
Geoff.
Hudson308 wrote:You should advertise these in the WTN, Geoff. Even with the high cost, there are likely people out there looking for decent mounts for their Hudson mini. I finally did that when I figured out which frost plugs will fit a stepdown 6. Even though I'll never get rich on a sale here or there (I'm buying 'em retail and selling for a bit more), enough people need them now and again for me to keep stocking. You may be someone's only cure for a part sourcing headache.
Interesting. I got my plugs from my loacal parts store yesterday and put them in my motor I am building. They had them right on the shelf. Maybe I got lucky for the first time.;)0 -
For front mounts for your Jet go to NAPA and get Belkamp 602-1054 @ 7.44 each.0
dave s wrote:For front mounts for your Jet go to NAPA and get Belkamp 602-1054 @ 7.44 each.
Well, it seemed like a good idea at the time, but I couldn't even post them out at $7.44!!!!0 -
Dave, 602-1054 is a late 60's Chevy V-8 motor mount. They worked on daughter Saras Jet however it has a Chevy V-8 motor.If you do have a good Napa number KGAP will start stocking them.
Thank you0 -
springspeeddemon wrote:Dave, 602-1054 is a late 60's Chevy V-8 motor mount. They worked on daughter Saras Jet however it has a Chevy V-8 motor.If you do have a good Napa number KGAP will start stocking them.
Thank you
Count me on needing a pair!0
