Rocker panels
manditory=mandatory
you should be able to get body parts from Bill Albright, in sunny and HOT California. He's on the board here, look for Bill A.....
Also, if you don't you should belong to the HET club. They produce a publication called the White Triangle News, and in there you will find a wealth of information, as well as valuable contact information for people selling a lot of the parts you might be looking for. Hit up Sam J on here, he can get you guided in the right direction....0 -
As to the sheet metal, it seems to me that Ken Amman has a bunch of that; you might try contacting him. (I don't have his contact info. nearby, but someone will hop in here to give it to you. Meanwhile, you might want to join the H-E-T -- if you haven't, already -- which is a great clearinghouse for all that sort of stuff. I'd guess the vast majority here at the Forum are already members. The home page is at http://www.hudsonclub.org/0
I think Stu Coleman in Livingston, Montana was advertising a bunch of sheet metal parts, too.0
For long wheel base on the right they are not going to be found. Amman has some short wheel base for both.
If someone has one for the right/left they are usually keeping them.
Can retrofit one from a 4 door but those two are getting slim to none.0
- 175 The Flathead Forum
- 602 Vehicles
