Step-down Master cylinder # ? ?
I'm wondering if some of the more experienced, long-time Hudson owners could provide me with a good part # for a brake master cylinder for one of my step-down's ? Went out to the garage Sunday and slid in the driver's seat, pushed down on the brake pedal only to feel that sickening experience of a 'spongy' brake pedal ! ! Feels like it's down to the mechanical reserve, so I'd say it's time to round-up some brake parts ! Does Dave Kostansek still have master cyl.'s and wheel cyl.'s with the stainless steel sleeve pressed in ? Thanks for any help with #'s
'47HUD
'47HUD
you want a wagner no 3081 over as hundred dollars at your local parts store. you can get them on e bay from as Hudson club member who lists them at 49.95, BILL ALBRIGHT VINTAGE COACH, FONTANA, CA0
The last time I needed one, I went to NAPA, and waited for the oldest guy behind the counter who knew how to read a book, and he was able to look it up. They had one in stock. I think it was around $50.00.0
Thanks Bill and Dany, any chance you can provide some part #'s for the wheel cylinders for a '51 Super 6 ? I might as well dive into all 4 corners while I'm at it, then I know I won't have to wonder about these components too ! ! How about #'s for the 2 front brake hoses ? Thanks fella's !
'47HUD0 -
Here ya go, this was posted some time back. For reference, I paid 12 & 18 bux for each whl cyl, and 101.53 for the master in Jan of 06 for my 50 S6.
Wheel cylinder Coni-Seal WC13600 40-54 Hudson LR 15/16 in Bendix 33600 Midas 1024 Wagner 59240 Auto Spec 84001 EIS 9150
Wheel cylinder Coni-Seal WC13221 48-54 Hudson RF 1 1/8 in Bendix 33221 Midas 1031 Wagner 18291 Auto Spec 84010 EIS 40025
Wheel cylinder Coni-Seal WC13601 40-54 Hudson RR 15/16 in Bendix 33601 Midas 1025 Wagner 59241 Auto Spec 84002 EIS 9151
Wheel cylinder Coni-Seal WC13220 48-54 Hudson LF 1 1/8 in Bendix 33220 Midas 1030 Wagner 18290 Auto Spec 84009 EIS 40024
1948 -1954 Hudson Master Cylinder- WITHOUT POWER BRAKES-Napa/United # 3081
1948 -1954 Hudson Master Cylinder Repair Kit - W/O POWER BRAKES Napa/United # 138
1951 -1954 Hudson Front Brake Shoes - Raybsetos #263
1951 -1954 Hudson Rear Brake Shoes - - Raybsetos # RR-55
1948 -1954 Hudson Front Brake Shoes - 11" X 1 3/4" - Napa Rayloc# RS-55
1948 -1954 Hudson Rear Brake Shoes - 11" X 1 3/4" - Napa Rayloc# RS-55
1948 -1954 Hudson Front Brake Shoes - 11" X 21/4" - Napa Rayloc # RS-18
1952 - 1954 Rear Brake Hose - Wagner #24404
1952 - 1954 Rear Brake Hose - Napa/United 11149
1948 - 1954 Front Brake Hose - EIS SP-1418 or Napa/United 10303
1951-1954 Wheel Cylinder Repair kits - Front Raybsetos WK-13
1951-1954 Wheel Cylinder Repair kits - Rear Raybsetos WK-36
Wagner/Lockheed Number for rear wheel cylinders for 1948 -54 Stepdowns FD-2447
Bendix Numbers for wheel cylinders for Stepdowns 1 1/8 inch cylinders 3128 ( left) , 3129 (right)
Bendix Numbers for wheel cylinders for Stepdowns 1 1/16 inch cylinders 3461( left) ,3462 (right)
EIS Numbers for wheel cylinders for 1952-1954 Pacemaker / Wasp Stepdowns 1 1/16 inch
Hudson Axle Seals Dave Kostansek (440 293-4079) has all but the rear inners. For those, I don't know of a current equivalent seal available. Maybe someone else out there has found one. They're still showing up at flea markets within the club. The old NAPA number for rear outer was 49218; it's now CR 17310. Fronts are CR 15960 or National (?) 482253
51 Pinion Seal (Others?) NAPA 47897 or National 473310 -
Call Kenny Cordle at 740-983-1700 for a new master cylinder that is identical to the original and very inexpensive. He is a club member and a lot of Hudson club members have bought them and they work great.0
That Is Who I Was Referring To Kenny Will Sell You One Reasonalble. Bill Albright, If You Cant Find Wheel Cyls From All The Info Provided, I Stock Them And Get 20 Bucks Each0
Many 'Thanks' to all Hudson gents who replied to my question's about the brake parts #'s for the step-down's, little help-ful things like this are what make the H.E.T. club the outstanding organization that it is. Thanks again for the help !
'47HUD0 -
Dave K does have the inner seals. I just received 2 from him today!
J Cronk0
