34 Hudson 8
Hi there. I have a 34 Hudson 8 long wheel base Sedan twin sides mounts ect.
I am looking at the 34 Teraplane coupe body on Ebay. I would like a 34 Hudson 8 coupe and see this as a good option to use the Teraplane body which I assume is the same as the 8. Has anyone done similar with the Long wheel base sedan and where is the extra length. Any Help?????????
If you have the Model LL, 123" WB model, then I think you'll have a problem installing a body from one of the other series, as the difference in length is in the chassis at a point behind the firewall.0
Park W wrote:If you have the Model LL, 123" WB model, then I think you'll have a problem installing a body from one of the other series, as the difference in length is in the chassis at a point behind the firewall.
I thought that might be the case I will have to do some research.
Thanks
Regards Trevor0 -
THERE IS A 35 COUPE BODY ON EBAY RIGHT NOW AT THIS WEB SITE
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=110168059310&ssPageName=STRK:MEWA:IT&ih=0010 -
Hi there.
Yep that was the one I was looking at but would probably need to locate the shorter wheelbase 8 cyl chassis. Mine is 123 Inch
Kind regards Trevor0
- 175 The Flathead Forum
- 602 Vehicles
