brake drum puller
bellbigdawg
where does one get a brake drum puller so I can do my brakes on my 41?
Got mine on ebay. Snap on.....for 75 bucks0
WHEN YOU GET YOUR PULLER ( TRY A TOOK RENTAL PLACE ) THE USE IT THIS WAY
http://groups.msn.com/HudsonEssexTerraplaneBulletinBoard/rearwheelpuller.msnw0 -
...or, phone around amongst your tool rental places. Or, if you're in a local old car group like AACA, VMCCA or a Hudson chapter, ask around at the next meeting; maybe someone would loan you one.
It's a good investment and if you keep your eyes open, you may be able to get one fairly cheaply.0 -
bellbigdawg wrote:where does one get a brake drum puller so I can do my brakes on my 41?
Make sure to pull,clean,inspect and repack the rear wheel bearings.Also replace the rear outer axle seals.:)0 -
thanks!! got 'er handled now! wow, talk about a quick solution to that problem!!0
