Cooling System Flush Kit
On which hose of a '50 Step-down would one install a modern cooling system flush kit adapter? Is it the one going from the pump to the fire wall?
Since I need new hoses I am planning for that nice day after Christmas when I can pull the car out of the garage and flush the cooling system.
Ken U-Tx wrote:If you put it on the hose running from heater core at firewall to the waterpump, most of the water will just flow thru pump, down the lower hose and up out the radiator filler, bypassing the block. To get flushing of the block passages, especially reverse flushing of that brass distribution tube, you need to put the T connector with the cap on the hose that comes out the right side of the cylinder head
Got it. Fire wall to Block.0
