Source of electrical parts for my '37T?
Dave Kostansek. See his ad in the latest WTN, includes his contact info.0
Also,try Lester Harris at (775) 267-25590
'37 Terraplane tune-up parts.
Dist. Cap: Standard Motor Parts AL-92 NAPA AL59
Ign. Coil: Standard Motor Parts UC-14X NAPA IC7
Points: Standard Motor Parts AL-5661X NAPA CS709
Condenser: Standard Motor Parts AL-111 NAPA AL869
Rotor: Standard Motor Parts AL-102 NAPA AL32
Spark plug: Autolite 295.0 -
Dave would have these, or you could buy them at your local Napa store. Cap is a al-59 points cs709 cond. al-869, rotor al-32 .
Chuck G.0 -
This web site is the best thing since sliced bread . In the 2 min. it took me to respond Mars55 had it for you . This is were i got the info. from him and i went to my local Napa and they had every thing in stock!0
mars55 wrote:'37 Terraplane tune-up parts.
Can you help with the same series of references/numbers for the '27 & 28 Essex? thanks0 -
Well, that was simple. There is a NAPA store within walking distance. Thanks everybody!
John0 -
ESSX28-1 wrote:Can you help with the same series of references/numbers for the '27 & 28 Essex? thanks
Not much help. For the '28 Rotor: Standard AL-64 and NAPA AL32 The coil is UC-14X. The '27 lists a coil, Standard UC-14X and that it. The parts listed for the '37 might work on the '28. The '28 uses a Auto-Lite IGB-4014 distributor. There is no listing for that model, but other IGB model distributors use those parts with the except that some IGB model distributors use a Standard AL-63 condenser which has wire lead.0
- 175 The Flathead Forum
- 602 Vehicles
