Source of electrical parts for my '37T?
jtroberg
jtroberg Member
Gentlemen:
I need a new rotor and distributor cap for my '37 Terraplane 6. Unfortunately, it has been so long since I purchased these items that I don't know where to go. Where do you get your electrical parts?
Thanks!
John
  • Jon B
    Jon B Administrator
    Dave Kostansek. See his ad in the latest WTN, includes his contact info.
  • Nevada Hudson
    Nevada Hudson Senior Contributor
    Also,try Lester Harris at (775) 267-2559
  • mars55
    mars55 Senior Contributor
    '37 Terraplane tune-up parts.
    Dist. Cap: Standard Motor Parts AL-92 NAPA AL59
    Ign. Coil: Standard Motor Parts UC-14X NAPA IC7
    Points: Standard Motor Parts AL-5661X NAPA CS709
    Condenser: Standard Motor Parts AL-111 NAPA AL869
    Rotor: Standard Motor Parts AL-102 NAPA AL32
    Spark plug: Autolite 295.
  • Dave would have these, or you could buy them at your local Napa store. Cap is a al-59 points cs709 cond. al-869, rotor al-32 .
    Chuck G.
  • This web site is the best thing since sliced bread . In the 2 min. it took me to respond Mars55 had it for you . This is were i got the info. from him and i went to my local Napa and they had every thing in stock!
  • ESSX28-1
    ESSX28-1 Senior Contributor
    Can you help with the same series of references/numbers for the '27 & 28 Essex? thanks
  • Well, that was simple. There is a NAPA store within walking distance. Thanks everybody!
    John
  • mars55
    Not much help. For the '28 Rotor: Standard AL-64 and NAPA AL32 The coil is UC-14X. The '27 lists a coil, Standard UC-14X and that it. The parts listed for the '37 might work on the '28. The '28 uses a Auto-Lite IGB-4014 distributor. There is no listing for that model, but other IGB model distributors use those parts with the except that some IGB model distributors use a Standard AL-63 condenser which has wire lead.
