WILCAP Adapters
Has any one here or know someone that has installed the WILCAP block to trans.adapter on a 48-54 Hudson Engine? When using the 55-56 crankshaft and a 200R-4 GM. trans. They sell a complet kit and any info would be of help .
Thanks to all Rudy.
Thanks to all Rudy.
Rudy,
I have inquired on a Wilcap adapters in the past but ended up using an adapter from Dany Spring and another from Randy Maas and both are excellent. Dany's uses a 3/4 alum plate with dual bolt pattern while Randy's adapter went over the front pump with the Hudson bell. I think Randy will build to either crankshaft but (I think) Dany still has adapters on the back burner at this time. Chuck0 -
Thanks Chuck, I will contact both. Hudsonly Rudy0
