Which Carbs for TwinH?
rambos_ride
Which carbs do I need and are these reasonable prices?
http://www.49c8.com/images/fp/Hudson Downdraft Carburetors.htm
  • Dan, The prices seem a bit steep.
  • I hope those are steep as I think I may need to replace my carbs.
    Harry
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    Dan And Harry I Have The Kits To Rebuild Wa1 Carbs I Had A Pair Ot The National Meet Last Summer And Sold The Pair For $275 They Were Rebuilt And They Were The Hornet Carbs 2 15/16 Base Not Wasp Or Jet ( Smaller Base Bolts Centers2 11/16 ) I Also Have A Pair Them
    Why Not Rebuild Your Carbs If You Need A Pair I Can Most Likely Find You A Hornet Pair 2 15/16 Base To Rebuild Let Me Know
    Hudsonly
    Paul
  • Yeah, I think the carbs on my twin h, I picked up at a hudson swap meet, in carlisle two years ago, for like $10 each. These should be carbs you should be able to find for around $20-$50 each, rebuildable. Check eBay, they pop on frequently, look up WA-1, or the like and use 340 marked on the base as to identify what you need. The listing you got there, the prices are way out of line. Make sure you get good kits, some of the kits are not as nice as others. I would have faith that the kits that Paul has are the good ones. You will find that some of the folks that sell carb kits for everything under the sun, the WA-1 kits have ill fitting gaskets.
  • Browniepetersen
    At those kind of prices, I hope that I never have to replace mine. I did get a couple of rebuild kits from NADA.
  • Rambo, you want 2113s or 968s (I think thats right). We've frequently bought them in pairs with tags in nice rebuildable shape for $10-20 each. (even recently this year). Those prices seem way out of line considering what the complete kits cost.
  • rambos_ride
    Sure - I was hoping at those prices to be off-the-shelf-bolt-on-and-run-condition :)
  • PAULARGETYPE
    Dan
    I Don't Think There Will Be Any Running Shoes At Those Prices Maybe A Old Pair Of "chuck Conners All Stars" Hi Tops Of Course
