TwinH - Carb Spacer Gasket
rambos_ride
I just won this item on ebay - I'd bet dollars to donoughts this is the spacer gasket that is made for this application.
If we have 1 and a part number...maybe we can find more - or better yet aftermarket suppliers!
  • Part no probably goes to a Chevy, but they used W1s thru 49. Should work.
  • rambos_ride
    The bolt pattern measures the same from what the picture shows - the only issue is the exact thickness and if the center hole is large enough.
    I'll let you all know when it comes in and see if it does fit.
